ONTHEGRIND
Nov 12 2010, 06:52 PM
silver74insocal
Nov 12 2010, 08:21 PM
lets do this!!!
ONTHEGRIND
Dec 9 2010, 04:03 PM
Dec 9 2010, 04:20 PM
QUOTE(ONTHEGRIND @ Nov 12 2010, 04:52 PM)
since I am not far from Jerry woods
Say hi to Rich Walton from me when you're over there ...
This thread will be interesting to watch.
ONTHEGRIND
Dec 9 2010, 04:28 PM
Yeah I thought I was gonna tear the engine apart and build it but I am just going to leave it as is and just put it in the car and get it running.. I need to finish this so I can start on the next project..
Scott S
Dec 9 2010, 04:54 PM
Did you just buy this car, or was it recently for sale? I really think it is great looking - and I am usually not a big fan of the 916 stuff. Fun to watch it come together!
FANTASTIC long nose. Steel or glass body work? I really want an ST replica some day.
Good stuff!!
ONTHEGRIND
Dec 9 2010, 05:24 PM
Thanks I have had the car for a few years now.It had a 1.7 Then I started having issues with the 1.7 So i was going to sell it and work on the 911 but decided I was going to do the swap..
The white car is all steal.. probably gonna use a 3.0 iroc front bumper
ONTHEGRIND
Dec 17 2010, 03:21 PM
ONTHEGRIND
Dec 17 2010, 10:18 PM
silver74insocal
Dec 17 2010, 11:35 PM
looks great! hows the car? is it ready for the new power plant ? any stiffening happen yet? (thats what she said) ..what brakes are you currently/going to run? sticking with the 901 gearbox? please elaborate..thanks and keep up the good work
Dave
ONTHEGRIND
Dec 18 2010, 11:44 AM
Well i am fixing some monor rust issue's on the body when i am done with that will be doing some stiffining i do have one of mcmarks gt cages on the way, rite now my main focus is getting the engine in the car and deciding whether i am going to run the petersen oil tank or a stock mount set up.. Although i am leaning towards the petersen system ...
ONTHEGRIND
Dec 19 2010, 07:34 PM
plymouth37
Dec 20 2010, 11:40 AM
That engine looks great, nice work!
ONTHEGRIND
Dec 22 2010, 09:10 PM
ONTHEGRIND
Jan 8 2011, 01:52 PM
ONTHEGRIND
Jan 8 2011, 02:08 PM
ONTHEGRIND
Jan 8 2011, 03:35 PM
I was looking at other projects looks like alot of people with worse rust were using patches instead of whole pans what do you guys recomend ?
two-strokejohn
Jan 8 2011, 06:39 PM
Partial and full pans aren't that expensive from restoration design. If you're going to cut one out correctly, use the reproduction parts. Most of them fit like new. IMHO
biosurfer1
Jan 8 2011, 06:50 PM
where about in CA are you?
ONTHEGRIND
Jan 8 2011, 09:44 PM
ONTHEGRIND
Jan 9 2011, 02:02 PM
ONTHEGRIND
Jan 9 2011, 06:10 PM
McMark
Jan 16 2011, 11:34 AM
Pretty standard rust damage you got there. I'd pick up a reproduction rear floor pan and just use the sections that are rusted out if you want to take some acceptable shortcuts. Installing a full rear pan takes a long time, so it's not a project to be undertaken lightly, but the payoff is some peace of mind knowing that you've eliminated a lot of surface rust.
The rust on the vertical walls is the kind of stuff that I just make my own panels for. No complicated bends, so it's just trim & patch. Not worth the expense of buying formed pieces.
Check under your pedal cluster for rust as well. And what's up with the area where the seat belt reel attaches?
arkitect
Jan 16 2011, 04:04 PM
Great before and after shots on your carbs and motor, amazing the difference.
What did you do to make such crisp bends for your seat mount? Almost looks like put a slight cut on one side before the bend.
Dave
ONTHEGRIND
Jan 16 2011, 06:20 PM
Yeah i put a nice slice in them and then put tach welds on them..
ONTHEGRIND
Jan 16 2011, 06:37 PM
The front of the car looks good and solid around the pedals only the rear part had carpets.. As for the seat belts looked like jb weld i ground it off and the metal was real solid i am gonna use harness's so i am gonna delete the holes
