Eric_Shea
Nov 12 2010, 11:52 PM
Looking for the rubber mount that goes between the wiper motor and the front bulkhead.
Thanks,
E.
LotusJoe
Nov 13 2010, 12:08 AM
QUOTE(Eric_Shea @ Nov 12 2010, 09:52 PM)
Thanks,
E.
McMaster Carr Supply has them for a couple bucks each.
Regards
Joe
type47
Nov 13 2010, 06:23 AM
I just installed the wiper assembly in the project car yesterday! The mount on my assembly looks just like a fuel pump mount. As you probably found out ('cause you're posting here) it's NLA at PelicanParts.
http://www.914world.com/bbs2/index.php?showtopic=101785
914Sixer
Nov 13 2010, 07:19 AM
Eric,
I will send you one to PMB.
Eric_Shea
Nov 13 2010, 11:21 AM
Thanks Mark, All:
I was searching McMaster last night and thought about the 1x1 M6 unit but was going to measure this morning to be sure. Mark, if you have a great factory piece, send that on and I'll take care of ya.
Thanks for the link Jim... I'm going to add some measurements and a McMaster recommendation for those coming after us.
Thanks again.
E.
Eric_Shea
Nov 13 2010, 11:51 AM
For this application the 1x1 M6 unit is the closest that McMaster has. The factory piece seems to be 1.25" x .50 (32mm x 13mm). The factory piece I have may have been stretched over the years so... the 1x1 M6 may be fine for others. I'm going to see how the one Mark has compares.
Thanks again,
E.
type47
Nov 14 2010, 08:34 AM
QUOTE(Eric_Shea @ Nov 13 2010, 09:51 AM)
The factory piece I have may have ...
Any chance you could post a pic of the factory piece? I'd like to compare it to the one on the wiper assembly I mounted. Unfortunately, I didn't take off the assembly (but thanks scottyb ... ) and I wonder if the one on the assembly is factory. It sure looks exactly like a fuel pump mount. When I mounted the assembly, it seemed like the mount needed to be a tad longer because when I tightened the 6mm nut on the mount behind the bulkhead, I could hardly get the nut on the wiper part that sticks out of the cowl. I had to loosen the 6mm nut, then thread on the nut on the cowl, then go back inside and tighten the 6mm nut.
Eric_Shea
Nov 14 2010, 09:38 AM
Hey Jim,
I may have tossed it. I'll check today.
It is the same premise as the fuel pump isolators but I believe it's almost twice as long. Mine was torn in two but... the pieces measure roughly 1.25" x .5".
914Sixer
Nov 14 2010, 11:05 AM
Okay, here is a picture with measurements. Please note the OFFSET of this piece.
Eric_Shea
Nov 14 2010, 12:02 PM
That's it... funny, I thought that offset was just from it sitting in that position for 36 years... cool!
I've "got" to come to Boerne, TX one of these days... there "must" be a real "Lost Warehouse" there.
By chance... any fuel line and brake line clips (plastic ones) that you could add in the box?
914Sixer
Nov 14 2010, 02:30 PM
I will have to dig for the plastic clips. I have a bag of used plastic items somewhere.
Eric_Shea
Nov 14 2010, 03:45 PM
I just found the fuel line clips. I'm in need of a couple brake line clips though...
914Sixer
Nov 14 2010, 03:46 PM
No plastic clips.
Eric_Shea
Nov 14 2010, 04:06 PM
No worries... just found out the PP has them in stock. Done.
curt914
Nov 15 2010, 09:49 AM
Hi Eric
I dont know if you found your wiper part yet or not, but..
Auto Atlanta has them (genuine)
http://www.autoatlanta.com/detail.php?Part...al_number=12312about $10.00
Curt
Eric_Shea
Nov 15 2010, 12:31 PM
That would be great... maybe I could get George to take back the weird cable that came when I ordered a heater control cable. That was about 10 years ago... I still have that $4.68 cable in the top of my tool box as a reminder of what bad customer service is. (Silly me, I was asking for a product credit so I could spend more money with him).
Anywhooo... I'll bet I'm on that "list" of guys not to sell to.
Eric_Shea
Nov 17 2010, 11:56 PM
Mark. You're a saint. Many thanks!
I put a few of the mounts on my last McMaster order. I believe their 208 1x1xM6 would work in this case. It would be much more stout than the factory piece but you shouldn't have any problems stretching it the extra bit into place.
Here's what it looks like next to the real deal:
914Sixer
Nov 18 2010, 06:47 AM
Eric,
Your piece does look like it would be a whole lot better and not 30+ yr old rubber.
Eric_Shea
Nov 18 2010, 09:25 AM
I'm using the stock piece (Thanks again) but wanted to let others know there's a $2.00 replacement out there.
