[quote name='Bartlett 914' date='Nov 13 2010, 01:01 PM' post='1394057']
[quote]
I restored a rusty car with mine but I wasn't careful enough. I now have door gap problems and I am not sure how I will correct it.
[/quote]
The rotisserie is a great tool but in some ways it will accentuate the problems with a rusty car. Whatever bracing one may do with a cvar on jackstands is even MORE important with it on a spit. you now have all of the cars weight distributed between the two ends with the already weak center becoming even weaker. The car MUST be leveld and squared then braced properly THEN put on the rotisserie or you will have nothing but problems. I have done more bracing then alot
I have seen here do and have had cars move on me. I am constantly re-working my methods to get the best possible results.That is why I never made my bracing thread I spoke of a few months back. I had what I thought was the optimal solution, and as I fixed that car I found a couple flaws I have now reworked. If it works out better this time I will make the thread. The issue I ran into was simply that my initial mounting point could have been stronger at the doors, and my floor brace could get in the way on a more extensive repair. I have mentally worked out both issues, but have yet to make the actual mods. The door braces will get extended to bolt onto the seat belt location. Once the 1/4 panel is cut out there is too much flex at the latch post for my liking, and had I needed to replace the WHOLE inner long, my rear brace would have to b removed. I will be relocating it to attach to the firewall, and the side bar wil be removeable
Besides the whole point of this thread was that the guy has a 914 on the one he is trying to sell
