I have an option of converting my oil filter holder to no -bypass. my engine builder likes that idea, I do to. the probelm will be fitting a high pressure filter to the engine (2056 4 cylinder) what filters are you all using for when the bypass is blocked?
Is there a short version of a high pressure filter as i will be running a sandwhich adaptor to add an oil cooler. I could go with a remote mounted filter also
if so, where are some locations of remote filters that you all have used? (photos anyone???)
thanks
