Shopping at my local Harbour Freight type place and I saw this. It says : for top post batteries. Attach to negative battery post. 1/4 turn disconnects battery. rated 100 amps continuous, 600 amps cranking. Includes ATM-20 amp fuse for power bypass.
I always thought you disconnected the positive battery leed? And if you wanted to bypass to supply power on "all the time equipment" why fuse link the negative side?
It was about $3.00
