Ok, here it is:
The Situation:
- bought a complete '86 911 Carrera Front Suspension about 2 years ago.
had a shop put it in. also upgraded the MC to 911 19mm (early style 69-77 i believe).
improved braking a lot over the stock brakes but it had too
much bias to the front, the rear brakes didn't do nothing.
- replaced stock prop-valve with a "Tee". still stock /4 brakes in the rear,
braking got better, moah thumb in the rear, but under hard braking, the
front still locks up way to early.
- today, went and got '87 911 Carrera rear rotors and calipers and put them on.
big fu***ing HUGE calipers, vented and cross-drilled rotors and all.
put them on, bled the brakes, nice, firm pedal, test the rears. they work great.
get on the road for a test drive, and WTF?
the front STILL locks up WAY before anything else. you can feel the rears working,
the car goes down as a whole, no nose-dipping. same (street) tires all around, in
good condition.
The Question(s):
- Porsche changed the 911 MC in '78. i have the 19mm MC from a earlier 911 but
now i'm running 86/87 carrera brakes all around.
- What is the difference between the 2 types of 911 MCs ???
- does the later 911 MC have different valving that gives you more "thumb" to the
rear brakes?
- is there a "reverse" prop-valve that can limit the FRONT brake?
Brad and i sit here scratching our pretty heads ...
anyone? PLEASE!
Andy
