QUOTE(ppetion @ Nov 23 2010, 02:27 PM)
I need someone in the tri- state area (NY-NJ- CT) to help me ad just my dual webber carbs. I cant sem to get them right. help.......... I am in NYC will drive up to 50 Miles. Need this done asap. anyone in the northeast region or if you know of any mechanic.
Thanks all for all your advice. I took the car to a mechanic recommended by a member of this forum, (great guy)He checked my timing, my valves, they were all good. he made some minor adjustments to the dwell. the biggest issue was with the carbs that needed to be setup and a leak on the exhaust. There was a leak where the pipe is attached to the exhaust. took them apart and put them back together. Re-thread some bolts. he spent some quality time adjusting the carb’s air and throttle, clean my plugs and adjusted the linkage between the two carbs. I drove the car for about a 100 miles today and all I can tell you is that the fun has begun.
The drive was smooth I monitored the head sensor that I installed and the Temperature was between 300 and 350 the whole ride. My oil sensor temp stays a ¼.
My next step is to put the car back together. I will be posting this on the other threads that I have started related to this issue as it may be beneficial to other members.
Big thanks to Ray (Rmital) and Zach (Vaca Rabite) who gave me the motivation and help me make it that far.
