QUOTE(orange914 @ Nov 27 2010, 12:25 PM)
QUOTE(underthetire @ Nov 27 2010, 11:43 AM)
Also make sure your coil has full voltage on the + terminal.
inline resistor? how much? does compufire even run resistance??
Simple answer, with a bosch blue coil, no. Pretty much same set up as pertronix, with a little better separation between coil trigger points. Simple hook up, just red to coil +, black to coil - (trigger) and the body of it grounded to the distributor and heat sink paste between the module and the mount plate in the dizy.
