Spoke
Nov 29 2010, 04:09 PM
I have a bead on Fuchs 6x16 and 7x16 wheels but can't figure out if they are the correct backspacing for my 914.
I've searched now for an hour here and PP and haven't found much. The wheels are:
6JX16 911 361 020 43 forged-black star rim flange polished
7JX16 911 361 020 44 forged-black star rim flange polished
Can someone tell me if these have suitable backspacing for 5-lugged 914? Does someone have the chart with all the Fuchs wheels on them?
Thanks in advance,
Spoke
Eric_Shea
Nov 29 2010, 04:17 PM
Spoke
Nov 29 2010, 05:21 PM
Thanks Eric,
I don't see the 911.361.020.43/44 6x16 and 7x16 wheels on here.
What is the correct backspacing for the 914?
Eric_Shea
Nov 29 2010, 05:40 PM
The 6's should be
Offset 36mm
Backspace 112mm
The 7's are
Offset 23mm
Backspace 112mm
That wheel has two part numbers I believe so, the above 16's are the same.
Speak German?
http://www.pocg.de/technik/911/s_Felgen_auf_911.htm
Spoke
Nov 29 2010, 06:03 PM
I found the chart that I was looking for. I even had it bookmarked but forgot about it. It was under 911 Weights from Rennlist.
911 Wheel Sizes & WeightsSo these wheels are:
911.361.020.43
6x16
17LB
36mm offset
112mm backspace
911.361.020.44
7x16
18LB
23.3mm offset
112mm backspace
So these should fit the 914 just fine. I may have to roll the back fender a bit to fit.
sled9146
Nov 30 2010, 09:52 AM
There is one more 16" wheel that may be of interest to you, a 7" off of a 944. The 1986 Porsche 944 Turbo's came out with 7" and 8" X 16" Fuchs wheels, but were not the 911 offset. The 7's look like 6's from the outside and the same for the 8's which look like 7's from the outside(meaning the extra wheel width goes in and not out). Look at Eric's chart for the 8's and compare the 951 part number 8 with the 911 part number 8. I had 911 6's on the front and 944 7's on the rear of a 914
geniusanthony
Nov 30 2010, 02:37 PM
What tire size are you thinking? I am mostly curious in the back as my 7s are/where close before flaring or stretching.
r_towle
Nov 30 2010, 04:32 PM
they should all fit.
If they are a good deal, but them up...if you dont want them, share the lead...
I may be down in Allentown to visit a client on the 15th or 16th if you have some time I would love to grab some lunch and see your 930 again...
Rich
