74 2.0 with 96 mm cyls and Webcam 73, stock FI. Car starts easily, runs strong right up to redline, no backfire or any trouble at all, except that when coming to a stop the engine revs waaaayy down low and sometimes quits. If it keeps running, it rebounds up to 1100RPM and will yoyo a bit before settling at about 450RPM. If it quits, it will start right up again.
The decel valve had been removed by the overhaul shop because they said it was "leaking". I had another one on the shelf, with no leaks, and installed it, but it doesn't seem to make much difference.
The idle adjustment screw shown in the Haynes manual doesn't look anything like my throttle body, so is it the screw at the 7 o'clock position on the throttle body when viewed from the back of the car? How much adjusting does it take? I gave it a turn or two with no apparent effect.
Ideas?
