QUOTE(Boxer246 @ Nov 30 2010, 08:45 PM)
Just getting started with a '72 1.7 ......
As far as the fuel hoses are concerned, all the hose from the fuel pump into the engine compartment, going to and from the injectors is supposed to be "high pressure" I realize. But do most of you guys just use the smooth rubber high pressure 7mm hose? For originality's sake, is there any high pressure 7mm cloth braided hose available? Most stuff i'm finding doesn't indicate weather it is high pressure or not....even the Contitech stuff, which I assume is high quality hose.
I'd like to keep the engine compartment looking as original as possible as this car is really low mileage and unmolested.
Another question, somewhat related,....are the 1.7 injectors the same as 2.0 injectors? Found a good price on new 2.0 Bosch injectors and wasn't sure they are compatible with the 1.7.
You gotta be careful when trying to use "original look" fuel lines because the new gasolines blends will eat thru this stuff in a year or two.
to quote realred914,,
"5/16 inch is a great fit, wont fail with clamps. the 30R9 NOT the 30R7 is to be used, the 3R9 is lined with a flouropolymer (Teflon like) inner hose that resists the new gasolines (oxygenated fuel) use of the older 30R7 hose is NOT recommended with todays fuels. as the hose degrades the 50 psi rating degrades. Orignal style German hose is NOT lined and is NOT recommended anymore becuase of the changes in fuel mixture.
look for SAE 30R9 rating stamped on your hoses, if not there, dont use it."
from this discussion,,
http://www.914world.com/bbs2/index.php?sho...mp;hl=fuel+lineNot trying to spoil your original looking engine compartment,, but I'm sure you'd want to be safe too.
-Robert
