QUOTE(rhcb914 @ Dec 3 2010, 01:50 PM)
QUOTE(tornik550 @ Dec 3 2010, 01:24 PM)
QUOTE(rhcb914 @ Dec 3 2010, 01:19 PM)
QUOTE(sean_v8_914 @ Dec 3 2010, 09:11 AM)
the AA must be older. the current AAs have "AA" cast into the base fin.
I agree. The AA set that I used looked MUCH better than those, didn't have the slag between the fins either.
The AA ones are fairly old. Mine do not have a AA stamp on them but I still have the box and the box said AA (they were sealed when I got them).
I'm sure they are AA. Lots of people have complained about poor qualty. Judging by that photo I would definately agree.
By they way really appreciate you posting this. I really shows the differences!
Maybe some other folks can chime in and post their photos of different cylinders. Maybe an OEM casting, late model AA, Nickies, knock-off Aluminum cylinders, Birals, etc. If anyone has done any measuring and mocked up an engine with the specific cylinders post those comments too. What did you get for deck height, were there differences in height between the cylinders? I want details!
I really think this could be a very valuable thread for anyone building a motor.
One reason that I wanted to start this post was because when I was looking for cylinders, I found a lot of opinions but couldn't find much objective data. I wanted to get a good set however I was not very interested in getting a stock set bored out (I didn't have a stock set, shipping jugs is a pain, and boring is around the price of new EMW jugs).
I do not remember the exact numbers when I measured the cylinder lengths. I only did this on the AA cylinders and now the EMW cylinders. I was surprised that the AA cylinders were fairly regular. The EMW jugs have been precise on my quick measurements.
I mentioned this before but there is a significant difference in the way that the cylinders feel. I realize that this is very subjective but I really think the feeling difference is significant here. The AA jugs just don't feel as solid as the EMW or other jugs that I have.
This may explain the difference in "feel" of the jugs but one problem that I did notice was when I was setting up the deck height for my engine, I used a 2 inch wide flat piece of metal between two studs. When I torqued the the piece of metal, it impressing into the jug slightly. Obviously, this would be bad for head sealing. I replaced the damaged jug with the "unknown" jug and retried my deck height checking process. I did everything the same and the metal piece did not impress into the jug. To me, this suggests that the AA metal is not as dense. (After those issues, I decided to get a new set of jugs) I have not mounted the EMW jugs yet however I doubt there will be any issue.
Another issue that I had with the AA jug was that skirt cracked from very slight trauma. By that point, I had already made the decision to get new jugs.
Also, FYI, from what I understand, the EMW jugs are made in Europe by the same company makes cylinders for Deutz.
