jeff9146
Dec 3 2010, 04:17 PM
Hi there,
As winter job, I am planing to upgrade the suspension on my 6, which is stock.
In fact, I also own a 4 2.0L . As the body is to be restored next year, I have all the suspensions already restored ( sand blasted, black epoxy painted, new shocks ) and fitted with Elephant racing polybronze kits.
My question is: are the main parts (struts, wishbones, torsion bars and so on ) the same on the 4 and on the 6 ? And if differents, will they fit ?
Thanks for your help,
Jeff
r_towle
Dec 3 2010, 04:24 PM
early struts 1972.5 and earlier are different from the later ones.
Early rotors and clipers are also different and so are the ball joints.
the later setup has a better ball joint.
I think the torsion bars and thus the a-arms and adjusters are all different between the /6 and the /4
The /6 is a 911 T setup I believe.
Anything will fit on either chassis, but you cant mix and match struts, rotors, calipers and ball joints...they go as as set.
Rich
