QUOTE(realred914 @ Dec 4 2010, 08:42 AM)
some thign is wrong, you should not have to increase idle speed manually for cold weather at all, the aux. air volave shoudl give teh car more air when it is cold, when it is freezing cold, the fifth injector comes on to help making it richer still.
test that the air valve is fully open in your freezer.
the idle bypass should not need be adjusted when it gets cold.
Reverse that Red. I had to lower the RPM when it got colder by reducing air volume. But I think your correct that I check the AAR. BTW, my CSV is not used or needed here in SoCal. Thx Rich & Red.
Edit: Originally I believed that the idle increase was a effect of the increased air density that our old fi systems weren't compensating for. Guess not.
