DOUBLE CLICK ON PICS TO ENLARGE
tan driverside map pocket very nice, flap and spring included $50.00
Speed air 175 psi @17.4 cfm rebuilt with new BALDOR 3phase 5.0 hp
motor, 17" BROWNING flywheel and 6.750" browning drive pulley/sieve.
very nice unit with aprox. 10 hrs since rebuild. this is the heavy duty cast iron 2 stage pump. oil splash with site glass. rebuild included crank bearings, and new reed valves and seals. looking to get $800.00
motor cost was $438.97 rebuild was $690.00
i saw reciepts for it all. previous owner wanted to keep reciepts for taxes. i believe this to be true.
1967 911/912 driverside tailight assembly and lense in great condition both BOSCH with wiring intact $175.00
refinished and keyed front trunk lock/release beautiful $60.00 1 new red porsche key included
914 right side door pull's 15 available and all in great condition i have the bottoms as well either in vynil or hard plastic just add $15.00
door pulls (15)x $25.00
warm air guild plates 73-74 in perfect refinished condition. these have been chemicly stipped down to metal and primed and sprayed w/ wurths high temp satin then baked and cured. they now look new. very nice and perfectly straight
$75.00 pair
all hazard switches 20 available $35.00 early and late style all tested and look great too!
all headlight switches $35.00 early and late. all tested. NLA! $35.00
wiper switch w/ very nicely mounted and functional microswitch. this is too convert over too the electric w.wiper washer pump. i have a good vdo pump ictured in next listing. switch $40.00 pump $20.00
thanks
paypal to iefixitburke@yahoo.com
terry Burke
porsche914partsandcars@hotmail.com
shipping is at cost and will be calculated
