F4i
Apr 23 2004, 04:55 PM
Title says it all. I want to get the car on the road by next month.
914werke
Apr 23 2004, 05:08 PM
Ya mean this?
F4i
Apr 23 2004, 05:14 PM
yep, If I cut it out of cardboard do you think it will work?
Brad Roberts
Apr 23 2004, 05:16 PM
Nada. The fab shop held off on buying all the material. They said it was going to go down (the aluminum) they where correct. It was bought last week at 20-30$ less than it was back in Feb. I have NO idea when it is arriving. Hurry up and wait.
B
F4i
Apr 23 2004, 05:24 PM
Thanks. Story of my life. Aviation is like that. They HAVE to have it by 5:00. Won't be ready?!? Next thursday is fine then. I will just run a stock setup and bug you (brad) when it wears out.
Mueller
Apr 23 2004, 05:40 PM
Hey B,
have we decided who's car gets the prototype units??
as built they won't work on my car since I have the vanilla rice wheels...............
914werke
Apr 23 2004, 05:46 PM
Mike did you ever update the above image?
Its not exactly acurate if the intent was to replicate the 911 hubs with 4 studs and 4 mounting hollows instead of 5?
Or is that really whats being modded up?
Mueller
Apr 23 2004, 05:56 PM
Rich,
Both versions are going to be made:
4 lug vented/M calipers
5 lug vented/M calipers
(yes, you could buy a 911 front suspension or struts, but this allows you to use factory /4 wheel bearings (or VW bug or GTI rear or???) along with most everything else stock /4 to save money and the trouble of doing the conversion, if you can change your front wheel bearings, then you can bolt on kit.)
