QUOTE(recko911 @ Dec 6 2010, 08:30 PM)
Just checked voltage 12.5 volts car off, running 14 volts. Running with lights on. 13.5 volts. I also noticed that the alternator light is on I removed the gauge and noticed the bulb was dim very low and when I step on the brake it lights up further.
The bulb voltage is the difference between the battery voltage and the voltage at the voltage regulator. Remove the gauge and measure each terminal of the bulb to ground. Sounds like you have connections that have oxidized and are acting resistive.
Clean your grounds and maybe even your battery terminals.
