QUOTE(jeffdon @ Dec 7 2010, 01:20 PM)
QUOTE(mudfoot76 @ Dec 7 2010, 12:43 PM)
Ask your wife/gf if you can borrow her eyebrow tweezers (don't tell her why). Those are small enough you should be able to grab onto the jet. At least, it has worked for me in the past....
Once out, try spreading the tube with the slits in it a little. I usually just fit a tapered punch into it and press a bit. That should make it seat more firmly in the jet holder for removal next time. I would not try to spread by sticking anything IN the slots.
This works well. I also use a flashlight and inspection mirror to get a better look at what I'm doing. When you spread the slits to make the jet fit in the holder tighter be careful not to bend them too far cause they will crack. (Trust me on this one). Also, try not to lose the small "O" ring. they're really tiny and easy to drop. I bought a bunch of them and extra idle jets, just to have around.
Cheers, Elliot
