neyen14
Dec 7 2010, 08:55 PM
I have a '72 914 and I am looking to change the 4 bolt pattern to 5 bolt. I have the front hub set up from a 911 along with the brake calipers and such. Will the current 914 brake master cylinder work or would I have to upgrade that as well? As far as the rears go, I am going to have the 914 rotors drilled out to the 911 5 bolt pattern. Do I have them drilled to use studs? Any help and experience anyone could share would be helpful.
