QUOTE(rick 918-S @ Dec 8 2010, 06:40 PM)
Build a fixture that will hold the front 914 chassis and the 911 rear chassis sheet metal, Build a floor between the front and rear chassis' with 356 floor pans and longs, then set the body over the married chassis and weld. Add sheet metal to tie in the engine compartment and front nose and inner wheel houses to the 356 fenders.
Piece of cake. Red Velvet cake..
Same idea, backwards.
Build the floor, get it square, level and held solid.
Put the rear suspension in place measured off the floor.
Make a jig from the rear suspension and floor to set the front suspension square.
Same thoughts....just I chose to start with the floor so I had a stable place to measure from...that took me a year..I think you adviced me more than once on how to get started...lol
now that I am going forward..the rear requires that I cut the tube in half to make room for the new transmission, trailing arms etc.
I am making that a bench built unit that I will weld in as a single unit..
I will most likely cut the front clip off for the front suspension..it is pretty simple to remove and it will give me access to the whole inner structure to measure. weld and get it all done.
The front sheet metal is really just spot welded at the trunk lip, and I can cut the fenders in front of th cowl and take the whole nose off in a piece...
the bonus is I can get behind the front of the nose and hammer and dolly out all the dents whiles it is off.
Its cold here...metal work and fire are fun in the cold.
gonna chop it too.
And maybe...but I will wait on this one...do a split window thing..
I may or may not do that.
the little b-pillar will be deleted and I will be using some more moderen windows and a few other tricks.
this is one of those cars that has been in planning for way to long..lots of details sorted out...now its just time to do it.
The thread does what we all know it does...it will make me work on it at least once a week.
RIch
