Ok,
So I am going to attempt to tackle the wiring for my swap. I have the complete wiring harness from the 2002 Suby TS wagon. I want to trim it down to the necessary loom for an engine and tranny swap utilizing the stock ECU. I have the Suby Technical manual on a CDROM with the wiring schematic for an SOHC 2.5 N/A engine and 5 speed trans.
From Tony's thread I found these list of connections:
brain
2 o2 plugs
3 for engine connection
fuel pump relay
main realy
ignitor
obd connector
purge and pressure switching solinoids ( 2 plugs )
connection to relay board
then loose wires are :
power
ground
speed sensor
temp sensor if you go stock
then you need wires from the alt
Is that it?
I am also looking at Small Cars Interface board to help with the OBDII codes.
I am an electrical noob so any and all help is most welcome!
Cheers!
Nate
