I haven't posted for some time but I thought this little project might be interesting
enough to thread.... I'll show the work on it so far then follow-up as I finish.
To start I glass bead blasted some 2.0L heads (VW-039 101 371A) in prep
for valve re-work and deck skimming. They are going on the TIV bike I'm building.
Here's a pic of the bike.
I'm getting ready to replace the mock-up engine that's
on it now with a rebuilt 2.0L using these heads.
When I removed the copper exhaust manifold gaskets I found that one of the four
sealing surfaces was damaged, question marks in the pic below. I don't know what
caused this as I don't know the history behind these heads.
Today I tig welded the 2 damaged areas.
I'll post pics after I finish machining the sealing surface on the Bridgeport.
