make sure that the light comes on when the key is turned to the "on" position. If not the fuse is bad. Then pull the regulator and if the light goes out there is a problem with the alternator. (unless for some reason the alternator plug is wired backwards or a wire in the harness is shorted.
the charge rate should be 13.6
QUOTE(the head @ Dec 14 2010, 12:51 PM)
the alt light is staying on and I have gone through the troubleshooting article on pelican the alts max output (df and D+ shorted) is 18v the b+ check (DF hooked to 12V) yields 16V. I have replaced the reg with a known good unit. Alt puts out a bit over 13v at 1500 is this a ground issue or do I need to change my alternator out?
