QUOTE(Joe Owensby @ Dec 14 2010, 08:05 PM)
There is already a mark on the flywheel. I painted mine with a little white paint to make it a little easier to see when looking through the hole in the bottom of the transmission. Turn the motor over until the mark is at the hole. This is the position to adjust both valves on the cylinder 2 or 4. The first time you do this, you can go to the top side of the motor and using a screwdriver pry the top piece of engine tin back a little so that you can place a small dot of paint at the top of the flywheel, 180 degrees away from the original mark. Once this is done, I just put the car into 5th gear and rotate the engine by pushing on the tires until one of the marks is at the hole on the bottom. Then, look to see which pair of valves are closed, either 2 or 4. Adjust both of these. Turn the engine over with the tires until the second mark comes up. If you do this by pushing the tires in the same direction as the car would be going forward, the next position will be the next cylinder on the firing order. Repeat this 4 times and you are done. For me, this is a lot simpler than trying to see which valves are open and closed, etc. and then trying to remember which ones I had adjusted. The other way may be better for some, but not for me. JoeO
Yes, I agree, I feel more comfortable with using TDC to adjust the valves, How I marked the flywheel is I set the TDC mark in the impeller inspection hole to TDC for cylinder #1, then crawled under the car to make my own mark on the flywheel, (although I marked it in the wrong place using the timing notch instead of the TDC "0" on the impeller), then spun the engine alternating the pre-existing mark on the flywheel and my homemade mark accordingly. So, today I just need to make a new homemade mark on the flywheel and re-adjust cylinders #1 & #3, since I adjusted #2 & #4 using the factory notch in the flywheel, They should be good. Thanks.
