You can't do it with a visual inspection. You would have to inspect the case's mating surfaces as well, but even then there may be no way. You'll find several possible conditions.
1. Never align-bored: The crank-bearing bore (OD) is unevenly worn, but reasonably close to std. diameter, regardless of the bearing ID.
2. Align-bored: You'll find an oversized OD.
3. Align-bored with the case mating surface milled: The crank bearing OD will almost certainly be back to std. unless it was bored to a specific oversized bearing set based on availability. Regardless, the cam journals will have been re-bored as well.
To check the bearing bores you take the case halves apart, put them back together and torque them to specification, and use a bore-micrometer to measure the crankshaft bearing bore diameters.
Bore mic's are very expensive so most folks don't have them. My dial-indicator bore mic's were about $600 - $700 each.
Good luck
