With the help of the folks on the board (Jeff Bowlsby) and some further research, I have completed the following pin listing for the 914-6 relay board:
914-6 14 pin Engine Harness ConnectorPin 1. Black/Red - Ignition (CDI)
Pin 2. Black/Blue - Ignition Distributor (points)
Pin 3. (Not Used)
Pin 4. Red/Black - Dashpot Throttle Positioner
Pin 5. Not Used (Sportomatic)
Pin 6. Red/White - Thermal Time Switch
Pin 7. Yellow - Starter
Pin 8. Black/Red - Ignition Coil
Pin 9. Green/Red - Oil pressure Warning Light
Pin 10. Grey/White - Cold Start Valve
Pin 11. Green/black - Oil temperature Instrument
Pin 12. Grey/brown - backup light switch
Pin 13. Not Used (Sportomatic)
Pin 14. Grey/brown - backup light switch
I referenced the following 914-6 wiring diagrams as well:
http://roadglue.com/forum/attachment.php?a...mp;d=1171141810http://roadglue.com/forum/attachment.php?a...mp;d=1170261354Please feel free to share this info if you feel it is accurate.
