QUOTE(TargaToy @ Dec 19 2010, 07:34 PM)
Is anyone using a Rennshifter in conjunction with a factory center console?
If so, ...mind posting a pic or two? Curious about mods required, etc.
The base of the Rennshift console is just slightly larger than the console factory shifter's hole. You only need enlarge it slightly and then replace the vinyl. Go larger if you are going to put a boot over the base. Other than that, no mods needed.
