Jeffs9146
Dec 21 2010, 09:58 PM
I have seen this before but why is it here and what does it do?
bcheney
Dec 21 2010, 10:09 PM
This looks like some kind of antenna booster with the coaxial lines on input and output sides....maybe it's for an old CB radio that someone installed or just for a regular AM/FM radio.
messix
speedo cables ?emissions service engine light ca model
Jeffs9146
Dec 21 2010, 10:13 PM
Interesting thought!! It looks like it hooks to the speedo cable but I have not traced it down yet! I was hoping someone just knew what is was!!
Kirmizi
Dec 21 2010, 10:23 PM
IIRC that box is part of the EGR/warning light system. Does your dash have the small EGR light?
Mike
Jeffs9146
Dec 21 2010, 10:26 PM
Yep!
OK, so I can go to an earlier speedo cable and eliminate this right??
Kirmizi
Dec 21 2010, 10:34 PM
This light!
Mike
ConeDodger
Dec 21 2010, 10:35 PM
QUOTE(Jeffs9146 @ Dec 21 2010, 08:26 PM)
Yep!
Yes. Just go to the early speedo cable and elimnate the box. You also no doubt found the only piece
of wood used in a 914!!
Since I see the Cap'n lurking I should add that the console is wood as well if you have one...
Kirmizi
Dec 21 2010, 10:36 PM
Yes, I have a '75 also; but have an earlier gauge panel sans EGR light and I'm using an "early" model speedo cable.
Mike
Kirmizi
Dec 21 2010, 10:38 PM
You also no doubt found the only piece of wood used in a 914!!
Yes, but it's highly-engineered German wood!
Jeffs9146
Dec 21 2010, 10:54 PM
Thanks all! Out with the old and in with the older!! lol
Older parts that is!
Eric_Shea
Dec 21 2010, 11:03 PM
That's a black box that your insurance company installed when you weren't looking.
Looks like a great place to hide your
Dec 22 2010, 06:34 AM
Funny timing. I'm taking apart my '75 and found the wired plug in the boxed in foam section (not wood) I took a picture to ask you guys what it was for but you beat me to the punch. thanks, mark
stugray
Dec 22 2010, 06:43 AM
"You also no doubt found the only piece laugh.gif of wood used in a 914!!
Since I see the Cap'n lurking I should add that the console is wood as well if you have one..."
Ah.... you forgot the original spare tire cover panel is plywood ;-)
Stu
Dec 22 2010, 07:04 AM
What about the backing for the door panels and backpad? Wood or fiberboard?
MDG
Dec 22 2010, 07:11 AM
QUOTE(mepstein @ Dec 22 2010, 08:04 AM)
Fiberboard. I've ordered the FG door panels from Morph for my '76 conversion. The boards on my car were fuched.
I am using the stock backpad board - still in good shape - but will be adding some fiberglass in the lower section behind the passenger seat. That's where I have the harness entering to hook up to the motronic box so a little modification is required.
914Sixer
Dec 22 2010, 07:17 AM
It was a California ONLY item. You should have TWO small dash lights, one was EGR and the other is CAT. CA emission control items.
