Sailor
Dec 21 2010, 11:20 PM
I am researching front sway installation. Read the tech article on the Pelican site which described bolting the U tab to the A-arm. I was wondering if this is a common technique or if welding is preferred? Can the tabs be installed without removing the A-arms from the car?
john rogers
Dec 21 2010, 11:33 PM
I did the tabs on my race car this way and it lasted over 10 years of vintage racing. Be sure to use grade 8 or better bolts and lock nuts. I did it with the A-arms on the car.
Eric_Shea
Dec 21 2010, 11:45 PM
You can weld them on the car. I like the cleaner look but as John says...either way works if done properly.
Grelber
Dec 22 2010, 12:37 PM
I bolted mine on a couple of years ago and haven't had any problems. Didn't have to take the A-arms off either.
Sailor
Dec 22 2010, 11:42 PM
Thanks all! I will probably bolt my tabs on since I don't have a welder or a clue how to use one. Couple more questions come to mind. What is the proper size bolt to use and how do you locate the tabs on the a-arm? The tech article mentions 5 1/8" from the ball joint, not sure if that is referencing the center or edge of the joint. Is the distance critical or is it just necessary for both sides to be consistent?
SLITS
Dec 23 2010, 08:52 AM
Each tab should be equidistant on the "A" arm so that the bar is loaded equally side to side. If they are different distances from the ball joint, the amount of force applied to twisting the bar would be unequal.
The 5 1/8" is probably from the center of the ball joint. I would have to grab and arm and measure it to be absolutely sure.
Jeff Hail
Dec 26 2010, 01:45 AM
Hi
