Jeffs9146
Dec 22 2010, 08:21 PM
I started with this!!!!
Jeffs9146
Dec 22 2010, 08:22 PM
Ended up with this!!
zymurgist
qa1142
Dec 22 2010, 08:41 PM
nicely done, now coat it with wax or something
moparrob
Dec 22 2010, 08:43 PM
0000 steel wool??
Jeffs9146
Dec 22 2010, 08:46 PM
I used "amazing" cleaner from the $ store, a wire brush and a pressure washer!
Steel wool would probably finish it off nicely!
TC 914-8
Dec 22 2010, 09:05 PM
Looks good, I once painted it to match the engine and sanded down the ribs, Good job. maybe some clear coat
bandjoey
Dec 22 2010, 09:15 PM
I've read if you don't wax/coat it with something that corrosion of a sorts will attach the metal..experts?
Lennies914
Dec 22 2010, 09:24 PM
"amazing" or "awesome" ? Either way it looks great!
Jeffs9146
Dec 22 2010, 11:03 PM
"awesome"
Yep you are right!! Two bottles at $1 each =
tradisrad
Dec 22 2010, 11:21 PM
Looking good; now paint it gray and don't forget to paint the 1/2 shafts. Mine is a but dirty, but the paint makes it easy to clean.
EdwardBlume
Dec 23 2010, 08:59 AM
Nice work!
r_towle
Dec 23 2010, 10:21 AM
QUOTE(bandjoey @ Dec 22 2010, 10:15 PM)
Its already started.
It oxidizes (sp)
Rich
914 shifter
Dec 23 2010, 06:10 PM
QUOTE(tradisrad @ Dec 22 2010, 09:21 PM)
Click to view attachmentwhat type of oil cooler is in this pic?
PanelBilly
Dec 23 2010, 07:16 PM
I heard a story Bout this guy who cleaned it for hours. Then he had it painted with an industrial primer. Then came the black gloss. Now the thing is sitting in the garage like some kind of art. I'm .......ah, he's hinking of pinstripping the thing to match his body color now. Some people just go so over the top.
And the paint add to higher temps too
Dr Evil
Dec 23 2010, 09:09 PM
For corrosion info and some coating info, check out the 31 pages of tranz notes in the link below. You do need to coat it now or it will start to quickly corrode. Once it starts to corrode, you need to remove the corrosion before coating it. PITA. Looks wonderful
Jeffs9146
Dec 23 2010, 10:00 PM
What link below??
mikea100
Dec 23 2010, 10:06 PM
QUOTE(Jeffs9146 @ Dec 23 2010, 11:00 PM)
What link below??
Here you go.
http://www.914world.com/bbs2/index.php?act...t&id=218669
Dr Evil
Dec 23 2010, 10:09 PM
The one in my signature that says "31 pages of transmission notes
(Click here) "
Jeffs9146
Dec 23 2010, 10:25 PM
Thanks Mike!
I don't have my settings to show signatures so I cant see it!
Dr Evil
Dec 23 2010, 11:45 PM
AH, that explains it. I need to be wary of that when replying from now on.
