Doug Leggins
Apr 25 2004, 12:05 AM
I have finally found some time to work on the car. So I've been out in the garage putting suspension parts back together. Most things are going pretty well. I am at a point of assembling the torsion bar adjusting levers. It looks like the position (angle) of the A-arm in relation to the support bar when I install the levers will have an impact on the ride height of the car. I sure would like to get it right the first time if possible.
Can I assemble the adjusting levers with the suspension not yet installed on the car and expext to get it close enough to be able to properly adjust the ride height after the suspension is on the car? If so, what should I measure/estimate?
Here is a pic of the assembly so far.
Doug Leggins
Apr 25 2004, 12:09 AM
If I follow the Haynes manual instructions, I think the a-arms should be angled like in this pic before installing the adjusting levers.
Any guidance on how to proceed?
Thanks
Gint
Apr 25 2004, 12:20 AM
It doesn't matter all that much. When you get the suspension on the car, it will be really easy to re-index the torsion bar caps since they are all shiny, clean and powder coated. It's harder to explain than it is to do. It's easy, really. Just slap the caps on for now with the a-arms parallel or angled downward ever so slightly.
Rusty
Apr 25 2004, 02:46 AM
Smoke chrome powdercoat. Very sexy.
-Rusty
Jeroen
Apr 25 2004, 04:53 AM
What Rich said... adjusting it is very easy and best done when mounted on the car
The fresh powdercoated parts look VERY GOOD
cheers,
Jeroen
Gint
Apr 25 2004, 09:14 AM
Hi. My name is Rich, and I own a 914...
You OK Jeroen?
Eric_Shea
Apr 25 2004, 09:19 AM
He got you mixed up with Richie Ginther... it's a good thing.
Eric_Shea
Apr 25 2004, 09:21 AM
Oh... and sorry... need to add some content to the thread.
What they said. You need to get the struts mounted up to them to see the final "drop" position. Then you mount the cap. So... just bolt the ole suspension up and do it when it's on the car.
Jeroen
Apr 25 2004, 03:49 PM
Crap! Sorry Gint!
Note to self: don't post before you had coffee
cheers,
Jeroen
