monkeyboy
Dec 24 2010, 04:40 PM
I have the early doors with the window regulator buttons. I have a new set of buttons. How do I get the old buttons out? I have tried to pry on them a little, but they aren't budging. Is there something I missed?
Hopefully I don't have to take the door apart again.
markb
Dec 24 2010, 06:26 PM
They're held in by a pair of prongs in the center of the button. The button has a tendency to want to come off, so if yours is on there that strongly, why replace it? Unless they're broken leave them in. If they are broken, pinch the prongs together & pull the button off. Press the new button on, and spread the prongs as wide as you can.
Mikey914
Dec 25 2010, 12:32 AM
I agree if the button stays on leave it.
watsonrx13
Dec 25 2010, 06:55 AM
I have a later window regulator and also the new buttons. I'd like to replace mine since they are worn down so much that they jump out of the track. How do I replace them?
-- Rob
21783mike
Aug 17 2011, 10:11 PM
May I ask where you purchased the buttons from..... mines missing on the driver side.
monkeyboy
Aug 18 2011, 10:07 PM
AA I think.
21783mike
Aug 22 2011, 03:31 PM
QUOTE(monkeyboy @ Aug 19 2011, 12:07 AM)
AA I think.
Alcoholics Anonymous sells 914 parts?
markb
Aug 22 2011, 05:16 PM
We have a bag of good used ones. How many do you need? Cheaper by the dozen.....
monkeyboy
Aug 28 2011, 10:37 PM
QUOTE(21783mike @ Aug 22 2011, 02:31 PM)
AA I think.
And has an awesome microbrew!
21783mike
Aug 29 2011, 10:24 AM
QUOTE(markb @ Aug 22 2011, 07:16 PM)
Only need 1 but should get 2 in case I need one in the future. You can email with details - mikesmowing@myactv.net
Mikey914
Aug 29 2011, 09:41 PM
Got the new ones in Delrin. They pop off with a plyers amd you can pop them on the same way. Do them in sets (2 per window) because you will not have to take it apart again for the other later. Lube the track with a little grease.
