[quote name='jjackson' date='Apr 22 2011, 08:46 PM' post='1464901']
.The front end really likes this years added weight.JJackson
No question that is where you want to put the weight.
I'd like to show up and run XP or EMod, where ever the most cars reside, but the set up is different.
With XP you can put the ballast where you want so.... Ha, good point maybe I should just build another splitter with a thick steel plate. That is an easy place to add 75 lbs and destroy cones at the same time.
You know I could use the same splitter, just tie wrap on the plate.
I'm liking this.
[/quote]
Last year at nationals, I was gridded next to the Zust XP car.He was carbon fiber body with plywood splitter-I was steel bodied with carbon fiber splitter-Things that make you go Hmmmm.JJackson
[/quote]
1/4 inch standard sheet weights about 10lbs per square foot. Could easily add about 7 sq feet on the bottom of my existing splitter. Like one sheet that would bolted to the existing splitter. Might have to reinforce the aluminum fasteners that hold it on, but could figure something out.
How do you use fuel as a weight compensator?
