Tom
Dec 28 2010, 11:48 AM
Anyone know about any interesting articles to share about camless engines?
Here is one link.
http://autospeed.com/cms/title_Camless-Eng...10/article.html Having infinitely variable cam timing would open so much performance and economy it just boggles my little mind!
And not having cam chains to worry about would be something positive also. Just imagine a 2 liter type 4 with heads that would essentially have dual overhead camshafts with infinitely variable valve timing. WOW!!
Tom
rick 918-S
Dec 28 2010, 01:24 PM
I have a friend that worked as an instructor at an advanced BMW tech training center. I was at the school and he showed me some BMW heads that had solinoids or something that were running the valves. Very cool. No loss of HP turning cams, no verio parts to fail.
r_towle
Dec 28 2010, 01:34 PM
From the article (which is dated)
International Truck and Engine Corp is another engine manufacturer poised to take a huge step forward in diesel engine design, announcing that it will eliminate camshafts from its diesel engines and replace them with electronic-valve timing systems by the year 2007
Did this happen?
Rich
r_towle
Dec 28 2010, 01:37 PM
begs to question.
Do valves need to be round?
A square port slide mechanism may be more durable and easier to build...
How about a triangle?
Rich
flipb
Dec 28 2010, 01:42 PM
QUOTE(r_towle @ Dec 28 2010, 02:37 PM)
begs to question.
Rich
For that matter, do they need to be shaped like valves at all? If electromechanically operated, couldn't it be something akin to a hinged "trap door" design?
RJMII
Dec 28 2010, 01:48 PM
like reed valves for a snowmobile or motorcycle engine?
Chris Hamilton
Dec 28 2010, 02:13 PM
QUOTE(r_towle @ Dec 28 2010, 11:37 AM)
Yes, they have to be able to rotate freely in the valve guide. I've seen what the destruction looks like when they can't rotate anymore.
jd74914
Dec 28 2010, 02:50 PM
Round are easiest to seal as well.
I'm not sure why they would need to rotate; it is a different application, but many high quality industrial valves are non-rotating to keep from scratching the seats (and hence ruining the sealing surface).
RJMII
Dec 28 2010, 05:40 PM
They rotate to seat better. When we switch valves in a head ina car we spin them on purpose with valve lapping compound to assure that the seat shape and the valve shape are identical and provide a really good seal. Round is easier to assure the seal because of the ability to spin them in this procedure.
PlaysWithCars
Dec 28 2010, 09:10 PM
Look closely at the alignment between a rocker and the valve stem. Where the adjuster contacts the valve is slightly off center to rotate the valve a little bit each time it is moved.
PlaysWithCars
Dr Evil
Dec 28 2010, 09:33 PM
Round is necessary. Points would focus heat and break down from heating up. Think how you have to smooth the combustion chamber to guard against hot spots.
Rand
Dec 28 2010, 09:40 PM
Rotary cam is nothing new. (google it)
Compact nuclear... Now that's where it's at.
Seriously though, rotary makes sense. Even if as primitive as centrifugal timing variation, it's all rolling with the flow.
On the contrary, solenoid-driven, or anything else that relies on stop and go motion is way more complex and inefficient and prone to quick wear (and thus more frequent adjustments to stay within spec).
jd74914
Dec 28 2010, 09:42 PM
QUOTE(RJMII @ Dec 28 2010, 06:40 PM)
I understand that lapping is used to match the valve/port together in order to promote good sealing. You do this whenever you assemble an industrial valve or, like you said, head.
The part I don't understand is the necessity of valve rotation while the motor is running. At that point there is no guarantee of even surfacing, and any crap that gets on the seat can randomly scratch it, messing up the sealing surface.
Rand
Dec 28 2010, 09:54 PM
You might be surprised how much valves rotate. Just by nature, it happens. I've seen some great videos... Maybe a link to one will show up soon.
kevin311
Dec 29 2010, 06:18 AM
http://www.pattakon.com/pattakonDesmo.htmMaybe not camless but it's definitely a new way to use a cam. This site has some really cool designs and some cool animations to show the function,
I'm not sure where I stumbled across this site but I spent like 2 hours reading all the pages
SGB
Dec 29 2010, 08:10 AM
Whoah!
Thas some cool chit.
I wonder if any of these ideas wil reach production.
ME733
Dec 29 2010, 09:49 AM
..........most all TWO cycle engines....(as we call them)....have no valves...as we Normally think of valves....and no camshaft....In past years their have been very few engine designers who have attempted to utilize this simple method applied to cars....In the diesel truck engine world their are "two" cycle engines....Their must be some reason this simple system has not been refined /developed for cars, but I certanily miss the point....Diesels turning 1200 rpm, or motorcycle engines turning 12000 rpm, surely their is some one smart enough to design a variable RPM /torque/HP , two cycle engine.
KaptKaos
Dec 29 2010, 10:10 AM
Obvious?
This is what I thought of when I saw the title. I don't have much else to add.
charliew
Dec 29 2010, 10:13 AM
Two cycle is just that. Twice as many power pulses as 4 cycle. As in 12 cylinders 4 cycle compared to 6 cylinders 4 cycle. Most 2 cycle motors are tuned with an exact exhaust system for the utmost power. The ones I am familiar with are not fuel efficient. My 350cc 2 cycle 69 kawasaki twin made 42 hp. It used a rotary disk on the crank with a notch in it letting the intake port open before the piston started up. Wider notch = more duration and more power at high rpm. Expansion chamber exhaust to tune the power band. When a rotary valve would come loose on it's splined sleeve on the crank the motor would have one cylinder that would only make power at one rpm and it would vary with how much the valve would free spin.
bembry
Dec 29 2010, 10:38 AM
You want camless?
Check out the Kugelmotor! Kind of like rotory does 3D.
http://www.youtube.com/watch?v=0CmGJucRDBk
manousos
Dec 30 2010, 12:22 AM
QUOTE(bembry @ Dec 29 2010, 08:38 AM)
You want camless?
http://www.youtube.com/watch?v=0CmGJucRDBkHere is another "rotary" engine (shown stereoscopically)
presented at
http://www.pattakon.com/pattakonRotary.htmand here is another cam-less engine (two stroke direct injection Diesel):
presented in details at
http://www.pattakon.com/pattakonPatOP.htmHere is the Youtube video of the engine running on Diesel fuel standing free on a desk:
http://www.youtube.com/watch?v=2ByEgfTTq1IThanks
Manousos Pattakos
Dr Evil
Dec 30 2010, 07:16 AM
Manousos,
Thanks for joining and posting. You have some very interesting designs
SGB
Dec 30 2010, 08:56 AM
I love the simplicity of these VVT and alternate combustion ideas
The stereo views are cool, but my simple brain won't let me "see" it right yet.
Manousos, are you sponsored for this research and development, or just gifted and compelled to make things?
manousos
Dec 30 2010, 09:29 PM
QUOTE(SGB @ Dec 30 2010, 06:56 AM)
"The stereo views are cool, but my simple brain won't let me "see" it right yet."
Quote from
http://www.pattakon.com/pattakonStereoscopy.htm :
To see stereoscopically, just hide the left image from your left eye and the right image from your right eye by your palms and then try to concentrate your sight on a small object located at the intersection of the line from your left eye to the right figure and the line from your right eye to the left image. The "software" is already into the brain waiting for activation. The result is stunning. "Manousos, are you sponsored for this research and development?"
No.
Thanks
Manousos Pattakos
