Fuel Injections Parts from ’73 1.7L :
Thermotime Switch, temp sensor controlling cold-start valve, 1.7-2.0,1970-76, (No longer Avail): $10
FI Trigger points: Bosch =311905301, Used, but perfect condition, (AutoAtlanta= $202.13): $25
Cold-start injector, VW =022 906 171 A, Bosch =0 280 170 018, (No Longer Avail.) $25
Aux air valve, VW =022 906 045, Bosch=0 280 140 007, 1.7 – 2.0, ’70-’76, (No Longer Avail.) $25
3-port fuel pump, VW = 311 906 091, 1.7 – 2.0, ’70-’76, (No Longer Avail.)
tested: Works well. $55
Fuel pressure regulator, VW =311133 030, Bosch= 0 280 160 001, 1.7 – 2.0, ’70-’76, (No Longer Avail. )$10
Throttle body, VW =022 133 067, from ’73 1.7L $25
throttle position switch, VW =022 906 111 B, Bosch =0 280 120 021, 1.7L, ’72-’73, (No Longer Avail.) $25
injectors, VW =022 906 031 A or 311 133 261 A, Bosch =0 280 150 009, 1.7L, ’70-’76 $10 ea.
ECU, VW =022 906 021 EU, Bosch =0 280 000 037, 1.7L =’72&’73, 2.0 =’73, idle mixture adj. knob $50
harness: complete for 1.7L, still flexible, outer insulation not broken $15
Terry
stewteral@verizon.net
