I built these for my ITB 914. They have a shortened strut housing. You can use the Rabbit struts or the double adjustable Koni inserts with a small spacer on the bottom of the strut. I ran them with the Koni inserts. These came off a 72. They use the early ball joint, but have the later rotor and calipers. The rebuild calipers and rotors are included along with Porterfield RS-4 pads that are like new. The centering ring was removed to allow the use of wheels that did not work with them.
$175.00
