I had a custom aluminum radiator made and all the measurements look ok, except where the fan switch screws into the radiator and then the 2 wires for the fan plug into at.
I told the guy it was 3/4" but I believe he put in a 1" bung.
My question is on the switch, on one side is stamped, 82/77 degrees C
and the other side 2/5
I'm not sure what that translates to or if it is a rating that tells the fans when to come on and off at?
I just need one size bigger with the same train of thought I guess?
