QUOTE(realred914 @ Jan 14 2011, 08:57 AM)
isnt the 914 tranny considered a 901 type tranny? im a bit confussed on the terminology here.
The 914 tranny is a 901 tranny with a 215 mm clutch.
The '70 - '71 911 is also a 901 tranny, but a 225 mm clutch was used and instead of depressing the clutch plate fingers for release, it had a special fork and throw-out bearing that locked into the clutch plate and the fingers were PULLED.
I believe that the tranny is is called a 911/01 or 02.
The only advantage to the 911 tranny is that it was geared for a 6 cylinder engine to keep the engine in the desired RPM range, so you could keep your pinky in the air while driving and brag at the local whine & cheese meetings (Ok, so the fuchin' clutch has more surface area).
