QUOTE(mepstein @ Jan 14 2011, 10:50 AM)
I realize these cars started rusting from day 1. Most cars made 30+ years ago are not on the road unless they have been restored. I'm just wondering if its worth putting the seam sealer back on a car that is going to continue to rust from the inside out.
I know/saw many East coast 914's that were rusted through by the mid 80's.
well lets assume you rinse all the salt out of the rusty seams,with HOT water,Dry, then with somereally thin epoxy paint,you get the seam painted,thin paint can can pennitrate the seam best,then use sealer. This can arrest the rust a good deal, the new seam sealer willhelp keep out more water. fail to seam seal will mean repair wont last as long.
Of course more extensive rust will return if the old rust gets wet again.
the best repair may not be economical, that would be to split the seams and treat/replace the metal
