Britain Smith
Jan 14 2011, 03:55 PM
I am search for the best option for a throttle cable on the Subaru conversion and I am interested to see what has been done. Let me know what you got.
-Britain
r_towle
Jan 14 2011, 04:19 PM
string or twine might be perfect if you use the little pulleys that match.
rich
Britain Smith
Jan 14 2011, 08:58 PM
Where are the Subaru conversion guys? What did you use to make your car go?
-Britain
pktzygt
Jan 14 2011, 09:13 PM
You shouldn't have to change it as long as your engine is placed near where renegade puts theirs. Of course I never fully connected mine when I had the engine in, but it looked to be the correct length.
Engine is back on a stand for the time being or I would go take pics for you.
Britain Smith
Jan 14 2011, 09:52 PM
I went from a 914/6 throttle cable set-up which I know longer have. In addition, I have changed my pedal assembly to a Tilton set-up. Do most people use the stock 914/4 cable?
-Britain
Britain Smith
Jan 15 2011, 10:25 PM
Wow, so nobody wants to share their set-up.
I have been looking at getting this throttle cable, but was wondering if there was an easier way.
http://rjes.com/html/throttle_cables.html-Britain
TonyAKAVW
Jan 16 2011, 02:37 AM
I used two throttle cables. I used a normal 914 cable and a normal EJ25 cable. I machined an adapter that joins the two (removable) and then an adjustable mount to hold the sheaths. It isn't elegant or pretty but it has worked for a few years.
Tony
Rod
Jan 16 2011, 04:08 AM
Hi Britain, Is there not a company over there that can make you the cable exactly as you need?? I have used a company over here in the UK who made a cable exactly my length and also with the correct fittings on either end for the application I had built at the time..
Your car is turning out to be amazing, you don't want a broken TC as your mid corner on full beans..
d914
Jan 16 2011, 09:21 AM
Bob(bigkat) used two cables.. Standard 914 and made an adpater connector to the suby piece..
sawtooth
Jan 23 2011, 11:08 AM
Stock cable works perfect for me with a slight mod. I cut the old rod type end off and replaced with a 3/8 cable stop. Fits perfectly into the suby throttle cable holder. The cable stop has a set screw but I also plan on filling with solder or braze to make sure it is permanent.
plymouth37
Jan 23 2011, 12:31 PM
QUOTE(sawtooth @ Jan 23 2011, 11:08 AM)
I did that before I got a custom cable and never had any problems with it.
sean_v8_914
Jan 23 2011, 12:35 PM
Terry cable will build it to your spec for $40
plymouth37
Jan 23 2011, 12:51 PM
QUOTE(sean_v8_914 @ Jan 23 2011, 12:35 PM)
I got my custom cable from them and it fits and works great.
Britain Smith
Jan 23 2011, 06:08 PM
Just ordered my cable from Terrycable, we shall see how it looks when it gets here.
-Britain
partwerks
Jan 23 2011, 10:35 PM
I used the terry cable on mine..........
