DanT
Jan 17 2011, 11:10 PM
I believe these are aluminum with a allen head set screw...to attach to the cable that goes to the trip meter numbers.
this is the little knob that sits below the dash to reset the trip meter
detoxcowboy
Jan 17 2011, 11:51 PM
member 914xprs has it.. his name is terry, he is a friend and good parts ource. I know he has it because I helped him with all his parts this past weekend at the Sonoma Fair Grounds, he is in Riverside CA. (So. Cal.)..
914werke
Jan 18 2011, 12:26 AM
Two styles ; Early as you described knurled steel I think, w/ a small set screw & late plastic knob, push to fit.
DanT
Jan 18 2011, 12:28 AM
If it will fit I would prefer the early style....this is for a '75. Does anyone know if they are interchangable?
thanks
detoxcowboy
Jan 18 2011, 12:30 AM
QUOTE(DanT @ Jan 17 2011, 10:28 PM)
thanks
Terry as above has the early one.. a few of them. send him a pm, this is what he does.
****yes they are interchangable..
koozy
Jan 18 2011, 01:23 AM
Hey Dan, let me do some digging... I'm betting I have one for ya
DanT
Jan 18 2011, 08:33 AM
thanks Mike
pete000
Jan 18 2011, 07:53 PM
Speaking of odo reset cables. I just put mine back together after having it fixed and the cable seems to bind when routed to the hole under the dash. I tried every possible angle for the cable, but it always seems to bind. Seems too long. It worked before I took it out but was still a bit tight to turn. When it is not bent it spins nice and easy.
Mine is a 74 and it has the plastic knob.
Any tricks to get this to work better????
jetboy
Jan 19 2011, 01:01 AM
I soooooo need one of these too. I guess im gonna PM 914xprs.
dangrouche
Jan 19 2011, 09:21 AM
cheapie fix is getting a knob from that has a setscrew from Radio Shack; this is what I use. I just let it hang down under the dash.
914werke
Jan 19 2011, 10:08 AM
QUOTE(jetboy @ Jan 18 2011, 11:01 PM)
Chk out my ad (link in signature) Pic on post #16
steeks
Jan 19 2011, 11:33 AM
I have an early one, I have no idea what a fair price would be. PM Me.
