a little less kick especially in the top rpm range. Although these days with old worn out engines, old vacuum leaking, lower injector flow injection systems consisting of mismatched components and bad fuel injection parts rebuilds you may not notice anything to the point where you would think that the pressure sensors interchange
QUOTE(76-914 @ Jan 21 2011, 10:48 AM)
So I started on my '73 yesterday. I should mention that this car started out as a 1.7 and is now a 2.0 GC. 1st I checked the MPS. Both coils were good and it held 10lb vac more than 2 min's, so I was elated. Until I discovered that the MPS was a 022 906 051E. As I read it, this is the '73 1.7 MPS.
The ECU is a 039 906 021a. What can I expect? Anyone out there with actual experience involving this marriage. PBLanders section on this is still under construction. Thanks ahead of time.
