913B
Jan 21 2011, 09:23 PM
Asking $55 + shipping
Thanks
BuddyV
Jan 22 2011, 01:31 AM
PM sent.
I will take it, and can pick up.
brant
Jan 22 2011, 05:08 PM
not trying to disrupt the sale what so ever
but mind if I ask a couple of questions just for educational purposes...
-what years were these in originally?
-are they back lit, or not (I know the early cars had different dash lighting)
-are all of the taco plate sensor cars ones with this guage?
(ie: would that be a matched sensor?)
thanks for everyones time
just trying to figure out what to look for in the future
brant
SLITS
Jan 22 2011, 08:34 PM
Brant,
As far as I remember (and that's not very far). They were installed in non-center console cars, '74 and up. The temp guage is for the Taco Plate sender, same as the center console temp gauge. The one imaged does not look like a 914 gauge (temp portion) that I have had possession of. The 914s I have had were white line to solid red.
It had to have been added at some point as that is is '73 and below Silver Dot combo gauge.
They are back lit just like any of the other gauges. You can add one in an early gauge by removing the parking brake lamp assembly (which I have never done). I believe you can also install the module for a 911 gauge in there too (which I will try just for the hell of it)!
And just for giggles, the beginning of the red band is 220 F or somewhere around there.
brant
Jan 22 2011, 09:17 PM
Thanks Ron
I know i should of started a seperate thread
but I really appreciate the info
too bad I forget as fast as I learn
but I do like learning new things
thank you!
I might try adding the temp to a standard gauge at some point... ron, do you know where to buy the temp portion seperate?
brant
dangrouche
Jan 23 2011, 01:22 AM
Brant all the info you seek is here regarding guages
http://www.p914.com/p914_gauges.htm
