QUOTE(vsg914 @ Jan 23 2011, 06:04 AM)
Jamie, I don't think the new 19 mm have the reset switch, but I'm not sure about that. You could unplug the wire and see if it goes out. Like was said earlier, could be the park brake handle.
the 19mm has the switch at least my new ATE one does..
On the M/C it's self where the pressure switch is. there is a little plastic push button next to the spade connector. More like so tiny it's hard to see.
push it in and you are good to go. You should be able to get to it if you turn the wheel to the right and snake your hand up in the hole to the M/C.
