since i have been out of work i have been working 8-10 hours a day on my car. but i did only work a half day on christmas. so far this is what i have done.
replaced rear console
replaced rear trans mounts
serviced inner cv's
replaced rear trailing arm bushings
replaced all rubber brake lines with stainless lines
bleed and adjusted the brakes
welded 02 sensor bungs in exhaust.
welded -8 an fittings on valve covers
replaced leaky oil pressure sensor
mounted dual carbs
new air filters
pulled a new fuel line thru the tunnel
replaced all fuel lines
rewired the car back to original. minus the FI and the seat belt warning system
made a gt deck lid
and probly a bunch of other things i have forgotten.
but now it is road worthy and i can drive it with confidence.
next thing i need to do is fix the odometer so i can start a log spread sheet.
then fine tune it with my wideband
then change the center console guages with modern ones. (engine information)
find a 914 umbrella cover
4 wheel alignment (anybody know a good shop in so cal?)
and then i can start to beautify it.
so far i am real happy with the way it is turning out. i tried not to cut any corners. this car is going to be my daily driver (when im not riding my motorcycles)
my jetting is pretty much spot on. but i will tune it for mpg.
here is what it looks like,
