QUOTE(pcar916 @ Jan 24 2011, 10:22 AM)
QUOTE(recko911 @ Jan 24 2011, 10:16 AM)
Would these fit a 73 914.
Yes, on both ends. You will use some of the transmission end hardware (washers) along with it, but it's a good compromise between rigidity and isolating the vibration.
I've used both solids and semi-hard plastics on the street but gave them up in favor of these 911 mounts.
He's talking about engine mounts ...
A '73 is a side-shifter that already has SOLID outer motor mounts and small rubber mounts between the engine bar and the engine case.
The 911 sport mounts can be used as *transmission* mounts on a 914 and as outer rubber engine mounts on a early tail shifter car.
In any case, i don't think solid engine mounts or solid transmission mounts belong on a DD.
