QUOTE(Lennies914 @ Jan 24 2011, 05:53 PM)
2.0l GC motor out of a '76. I tore the motor down two weeks ago with the intentions of a rebuild. After pricing out the parts and guestimating head work cost I've decided to go a different direction. After all, I already have a 2.0l car. Motor is definetly rebuildable. The cam shows some wear. The barrels measured out good. Two pistons measured bad. For a DD I'd replace pistons,rings, cam & lifters, crank & rod bearings, and have the heads done. $400.00 takes everything, flywheel, clutch, alt, tins, heat exchangers, and probally more. I am keeping the fuel injection system.
hi, i would be interested in the heat exchangers .
tanks
