mtburman
Jan 25 2011, 11:00 AM
I am updating a/c compressor on 1975 2.0, from york style to geo metro style, specifically looking for pictures of how compressor mounts and updated compressor mounts. I have left over mounting hardware from 911 Rennair update, compressor bracket.
Do I need to pull the motor or compressor replacable/reachable from top?
Does anyone have pictures of compressor mounting/updated mounting?
Does anyone have experience with this upgrade?
dr914@autoatlanta.com
Jan 25 2011, 11:12 AM
The compressor actually mounts below the right front sheetmetal and is driven with a serpentine belt. No longer the need to cut the sheetmetal!!! Works great does not rob hp like the old York, and weighs less!
QUOTE(mtburman @ Jan 25 2011, 10:00 AM)
mtburman
Jan 25 2011, 11:44 AM
Then i can repair the existing metal from the dealer install, so it sounds like I need to pull motor,
ClayPerrine
Jan 25 2011, 11:47 AM
QUOTE(dr914@autoatlanta.com @ Jan 25 2011, 11:12 AM)
It only works if you hook up the ground cable....
George, I would like to see pictures. I have the Sankyo compressor kit from IceAC on Betty's 914, and it works great. But I would love to see one that didn't have to have the sheet metal cutout.
Yes you will certainly have to pull the engine to execute a clean repair of the engine shelf. We have repaired a lot of them after installing the new compressor update kits.
QUOTE(mtburman @ Jan 25 2011, 10:44 AM)
mtburman
Jan 25 2011, 12:36 PM
It works great with the York compressor but causing the engine to stall in Phoenix heat, want to go with geo compressor to reduce HP strain, especially at idle. Car does have idle solenoid, helps somewhat, but i am looking to reduce how noticiable it is when compressor cycles. Will probably update the hoses as well but plan to stick with R12.
MarkV
Jan 25 2011, 09:38 PM
The Sanden compressor is smaller but you still have to cut the sheet metal. You can mount the compressor to the existing mount by welding on some tabs or by buying an adaptor plate. Here are some photos of my mount.
MarkV
Jan 25 2011, 09:49 PM
MarkV
Jan 25 2011, 10:37 PM
mtburman
Jan 26 2011, 11:42 AM
thanks, exactly what i need. I was already going to copy your condenser repair. Do current refrigerant hose ends fit sanden compressor?
Dr Evil
Jan 26 2011, 12:22 PM
Why could you not position the compressor lower so as to avoid having to cut shelf and tin? Nice pics, BTW.
zambezi
Jan 26 2011, 10:59 PM
Or higher so it can stay connected for engine removal.
MarkV
Jan 27 2011, 02:44 PM
That is an interesting set up. The belt is on the front of the fan.
I dont think my set up could be mounted any lower. The mount is set up like a hinge so that you can pull three bolts and leave the compressor when you pull the engine.
andys
Jan 27 2011, 02:54 PM
QUOTE(MarkV @ Jan 27 2011, 12:44 PM)
If I'm not mistaken, the smog pump on '75-'76 motors were mounted like that. Perhaps all it takes is a smog pump pulley and you're all set.
Andys
type11969
Jan 27 2011, 09:55 PM
Is that a smog pump setup running that compressor? I thought about doing that but was concerned about putting that much load on those bearings. Hmm
-Chris
zambezi
Jan 27 2011, 10:51 PM
No it is not a smog pump pulley. I think it is for a VW bus. The pulley is cast not the rubber mounted style like the smog pump. All the brackets I made myself along with the adjuster. I had to raise the Oil filler to have access to it though. My car came with A/C from the dealer so I wanted to keep it but modernize it to be more useable. I did not like the hard to access mounting of the stock compressor, or the butchery it takes to install one. I repaired all the stock sheetmetal back once I figured out how to mount it this way. Here are some of the build photos and one of the engine as it sits currently out of the car.
Click to view attachmentClick to view attachmentClick to view attachment
zambezi
Jan 27 2011, 10:53 PM
zambezi
Jan 27 2011, 10:54 PM
Final pic of it as it sits currently
MarkV
Jan 28 2011, 10:40 PM
Are you going to use the original hoses or are you going to install new ones ??
zambezi
Jan 28 2011, 11:58 PM
I installed new hoses and upgraded the fan to a larger higher output Spal fan.
mtburman
Jan 28 2011, 11:59 PM
I'll have new ones made up, stay with R12 but barrier hoses.
