QUOTE(ONTHEGRIND @ Jan 27 2011, 10:58 AM)
So I know its not a 914 question but I have a small powder coat oven that is no longer getting the heating elements to work anyone have any ideas what I should look into to getting it to work again the vent fan kicks on but no heat..
There is a small schematic in the back of the PDF. I would trace the circuit and make sure all elements have voltage on them. More than likely, either a blown fuse/circuit breaker or an open connection/wire. Looking at the schematic, I don't see any kind of fuse... So, the other thing it could be, is the switch. Again, a little time with a multimeter and you should be able to find the problem.
Almost missed it.. There is a thermostat which could also be bad.
If you take the panel off, and take some pictures we can also point out places to look.
-- brett
