The thought came to us when we kept seeing S-Caliper pistons flake and fail due to dis-similar metal fusion and original “plated” pistons. The question; why dis-similar metal when we could use similar metal? 930 calipers have aluminum pistons. 951 calipers have aluminum pistons. 908 calipers have aluminum pistons... why not S-Calipers?
The coating process was a key component. As technology progressed, so did the coating process. These new aluminum pistons are harder and more durable than their original or stainless counterparts. Our special DuroAno® Coating makes them the perfect piston for the S-Caliper.
They are feather weight was well. These weigh 1/2 of what a stock S-Caliper piston weighs.
Put an end to S-Caliper woes. These pistons will right the original wrong and last forever.
Pistons are
http://www.pmbperformance.com/catalog/item...552/8573492.htm
